Mám Daewoo Lanos 1,5 1998 63kW . Auto po ujetí asi 1 km začne cukat, motor ztratí tah a po ujetí cca. 100 m
motor chcípne. Když je nechám zchladnout po nastartování se závada opakuje. Nevíte někdo, čím by to mohlo být?
Kamarád, který mi auto opravuje už zkontroloval , co se dalo a neví si rady. PORADÍTE ?
Daewoo Lanos PROBLEM
Re: Daewoo Lanos PROBLEM
skus spravit jednoduchu diagnostiku podla tohto videa
http://www.youtube.com/watch?v=oNu6vMWp0_A
je treba prepojit pin A s pinom B na tomto konektore ADLD/OBDI ten by si tam mal mat, pokial nemas musis pouzit diagnostiku na OBDII - nepriklad cez servis
jednotlive kody maju takyto vyznam
nehovorim ze ti to na 100% najde chybu ale mohlo by sa zadarit
OBD1 Codes
12 - System OK (Pass)
13 - Oxygen sensor voltage not changing
14 - Coolant temp high (voltage low)
15 - Coolant temp low (voltage high)
16 - Knock sensor /circuit fault
17 - Injector circuit shorted
18 - Control module error (knock sensor control)
19 - EST signal / Crankshaft position sensor fault
20 - Unknown / Unused Fault Code
21 - Throttle position sensor / circuit fault (high error)
22 - Throttle position sensor / circuit fault (low error)
23 - Intake air temp sensor / circuit (high error)
24 - Vehicle speed sensor / circuit fault
25 - Intake air temp sensor / circuit (low error)
26 - Unknown / Unused Fault Code
27 - Air conditioning pressure sensor / circuit fault (high error)
28 - Air conditioning pressure sensor / circuit fault (low error)
29 - Fuel pump relay circuit fault (short to -ve)
30 - Unknown / Unused Fault Code
31 - Unknown / Unused Fault Code
32 - Fuel pump relay circuit fault (short to +ve) or EGR error
33 - MAP sensor / circuit fault (high error)
34 - MAP sensor / circuit fault (low error)
35 - Idle speed control motor error
36 - EGR error
37 - Unknown / Unused Fault Code
38 - Unknown / Unused Fault Code
39 - Unknown / Unused Fault Code
40 - Unknown / Unused Fault Code
41 - Electronic spark timing 'B' (shorted to +ve)
42 - Electronic spark timing 'A' (shorted to +ve)
43 - Unknown / Unused Fault Code
44 - Oxygen sensor or circuit, lean signal (voltage low)
45 - Oxygen sensor or circuit, rich signal (voltage high)
46 - Unknown / Unused Fault Code
47 - Unknown / Unused Fault Code
48 - Unknown / Unused Fault Code
49 - Supply voltage too high
50 - Unknown / Unused Fault Code
51 - Control module error
52 - Unknown / Unused Fault Code
53 - Control module immobilizer
54 - CO potentiometer out of range (or not fitted)
55 - Control module error
56 - Unknown / Unused Fault Code
57 - Unknown / Unused Fault Code
58 - Unknown / Unused Fault Code
59 - Unknown / Unused Fault Code
60 - Unknown / Unused Fault Code
61 - CCCP solenoid / circuit fault (low error)
62 - CCCP solenoid / circuit fault (high error)
63 - Electronic spark timing 'B' (shorted to -ve)
64 - Electronic spark timing 'A' (shorted to -ve)
65 - Unknown / Unused Fault Code
66 - Unknown / Unused Fault Code
67 - Unknown / Unused Fault Code
68 - Unknown / Unused Fault Code
69 - Unknown / Unused Fault Code
70 - Unknown / Unused Fault Code
71 - Unknown / Unused Fault Code
72 - Unknown / Unused Fault Code
73 - Unknown / Unused Fault Code
74 - Unknown / Unused Fault Code
75 - Unknown / Unused Fault Code
76 - Unknown / Unused Fault Code
77 - Unknown / Unused Fault Code
78 - Unknown / Unused Fault Code
79 - Unknown / Unused Fault Code
80 - Unknown / Unused Fault Code
81 - Unknown / Unused Fault Code
82 - Unknown / Unused Fault Code
83 - Unknown / Unused Fault Code
84 - Unknown / Unused Fault Code
85 - Unknown / Unused Fault Code
86 - Unknown / Unused Fault Code
87 - Air conditioning relay voltage (low error)
88 - Air conditioning relay voltage (high error)
89 - Unknown / Unused Fault Code
90 - Unknown / Unused Fault Code
91 - Unknown / Unused Fault Code
92 - Control module error
93 - Control module error
94 - Unknown / Unused Fault Code
95 - Unknown / Unused Fault Code
96 - Unknown / Unused Fault Code
97 - Unknown / Unused Fault Code
98 - Unknown / Unused Fault Code
99 - Unknown / Unused Fault Code
No vzhledem k tomu, že se to děje po ohřátí, hledal bych něco co funguje až po ohřátí, tedy lambda..... zkus jí odpojit, mělo by to běžet v nouzovým režimu bez ní.... no a pak někdy takovou rotyku dělají rúzná čidla, jako poloha klikovky, vaček , teploty...... no a v neposlední řadě i zapalovací modul...... takový věci jako kabely a svíčky předpokládám máš zkouklý .....
