nějaké elektrické schéma zapojení,kam se co připojujeSERG Electronics píše:Sorry, but I do not understand your question ...tomg60 píše:lidièky máte nìkdo ten poèítaè v autì,docela mì to zajímá jak to funguje a jak je to zapojené
Omlouváme se, ale já nerozumím svůj dotaz ...
Super TRIP COMPUTER v. 4.2 SPORT - Lacetti - hatchback wagon
Re:
- SERG Electronics
Re: Super TRIP COMPUTER v. 4.2 SPORT - Lacetti - hatchback wagon
Dobrý den,
Pokud vás zajímá: zda máme návod na připojení TRIP COMPUTER v. 4,2 SPORT - Lacetti - hatchback vůz?
ODPOVĚĎ - ANO!
Good day,
If you are interested in: whether we have instructions on connecting TRIP COMPUTER v. 4.2 SPORT - Lacetti - hatchback wagon?
ANSWER - YES!
ODPOVĚĎ - ANO!
Good day,
ANSWER - YES!
Trip Computer vers. 4.xx SPORT
http://www.tripcomputer.ru/
So could you send us the instalation guide?
I'm very interested in this computer. Unfortunally I'm not an electrician, so I really want to know how I would connect your trip computer to my car. If you refuse to show the guide I'm afraid I'll have to refuse you goods, because you won't be trustable to me.
thanks
thanks
nuz exisuju podvodnici na taketo transakcie neverim.dobierka z rucky do rucky.aj tak by som sa bal.moje lacetti bude radsej bez ....hehe
- SERG Electronics
lacetti33 píše:nuz exisuju podvodnici na taketo transakcie neverim.dobierka z rucky do rucky.aj tak by som sa bal.moje lacetti bude radsej bez ....hehe
Good day,
I do not understand the essence of your question!
Dobrý den,
I don't understand podstatu svůj dotaz!
Pro sedan by nebyl?
Lze to provozovat i z LPG?
Nubira SE 1,4 16V
Orlando 1,8
Orlando 1,8
- SERG Electronics
Good day,karstn píše:Pro sedan by nebyl?
Lacetti - Hatchback & Wagon - Gasoline (Benzín)
Service support "SERG Electronics"
(495) 781-1722 from 11:00 a.m. till 18:00 p.m (moscow time)
Support forum:
http://tripcomputer.ru/forum/index.php
could you please answer my question? I wrote it in english, so I hope you understand ...
- SERG Electronics
Good morning,kuksx píše:could you please answer my question? I wrote it in english, so I hope you understand ...
No problem!
Link to the general instructions for use.
http://www.tripcomputer.ru/2008/Instr-4 ... 1-09en.pdf
Tak jsem ho dneska vyzvedl z pošty. Celé (i s platbou) to trvalo cca 3 týdny. Z Moskvy odešel 1. února a dneska byl na poště.
Naposledy upravil(a) pekrtek dne stř úno 10, 2010 19:41, celkem upraveno 2 x.
- FoXo
Tiez nexia ci iny model auta?
TAk pak dej vědět, jak to fakčí.pekrtek píše:Tak jsem ho dneska vyzvedl z pošty. Celé (i s platbou) to trvalo cca 3 týdny. Z Moskvy odešel 1. února a dneska byl na poště.
To zapojení asi nebude tak jednoduché. Sice je tam "pouze" sedm drátů, ale kam s nimi. Sám to určitě nezvládnu. Zatím to s Palikxem probíráme po mailu.
Už se to někomu podařilo zprovoznit na Lanosu? Návod je k tomu v ruštině, i když jsem měl slib, že pošlou v angličtině. Psal jsem ještě dneska o anglický návod a snažím se vzpomenout na mládí a přeložit ten ruský.
anglicky je tady o 3 prispevky vyse takze uplne v pohode.a ta barva co jsi nevedel je hneda.
ale dulezite je kam ty kabely pripojit v lacetti!!!!!!! ten odkaz ktery by k tomu mel smerovat vede kamsi do ruska -forum-a tam je jen lanos a o lacetti ani slovo.
asi si k tomu sednu a najdu si vsecky draty ale soudruh serg electronic by to mel uvest na pravou miru sam kdyz to prodava na lacetti.
edit
tak uz jsem si to nasel
jsou tam 3 jednotky motoru a kazda to ma jinak
predpokladam ze nejcastejsi bude sirius
vsecko jde pripojovat v aute u ridici jednotky motoru nemusi se tedy do motoru
vstrik-svetle modry/cerny-pozice 89 je to prvni vstrik a vic jich neni potreba(mam vsecky pozice kdyby nekdo chtel)
palivo-modry drat pozice 21
rychlost-zeleny/bily pozice 51
bat + nekde kde je stylch 12 v
ill treba na spinac sklonu svetel ke kabelu kde je napeti po zapnuti svetel
ign-nekde kde je napeti po klicku
a kostra je snad jasna.
pak jsou tam pry jeste 2 dratky na snimace teploty in a out
pokud mate digi klimu daji se mozna pouzit snimace pro klimu
vnejsi teplota -svetle zeleny/cerny-pozice B8 na ovladaci klimy
vnitrni teplota - zeleny pozice A16 na ovladaci klimy
pokud nemate digi klimu nevim zda auto nejake snimace teploty ma a ve schematu je nikdo neresi (nebo je neumim najit)tedy je to pokus omyl.
edit
tak a mame to namontovane
zapojeni neni slozite ALE
pripojeni fuel meter je na nic a musi se pripojit primo na vystup z nadrze-modry drat v parhu u ridice.
a dalsi zasadni problem
speed sensor je taky spatny ukazuje to rychlost 2,5 * vetsi nez ve skutecnosti jedete-tedy jedu 80 a ukazuje 200 km/h
a pripojeni napajeni je taky spatne ma prohozene draty ILL a ACC takze zapnete zapalovani a po 10 sec trip computer zhasne.zapne se az po rozsviceni.takze jsem je prehodil a a uz to funguje.
PLEASE SERG-ELECTRONIC why is speed wrong?really speed 80 km/h=200 km/h on TRIP COMPUTER
what i do for good speed?
doufam ze se tomu da rozumet a nekdo mi odpovi
