PILOT-07 ON-BOARD TRIP COMPUTER FOR LANOS
valeryss
Příspěvek od valeryss »
The onboard trip computer (OC) is an indispensable thing for the modern driver. Until recently it was not accessible to owners of inexpensive cars. It measures speed, the consumption of fuel, RPM of the engine and many other parameters. It is embedded instead of regular watch, keeping thus an opportunity for displaying the time and not changing the interior.
- displaying of fuel consumption instant value (litres/hour)
- displaying of fuel general consumption (litres)
- tachometer (RPM)
- speedometer (km/hour)
- displaying of traversed path, odometer (km)
- displaying of fuel consumption per 100 km of a trip (litres/100 km)
- clock and a calendar (hours, minutes, seconds, date, month, year)
- trips diary (number of a trip, duration, trip distance, max. and min. speeds)
- voltmeter of onboard voltage (V)
- thermometer (°с)
- signal on excess of speed
- signal on excess of RPM limit
- alarm-clock
- taximeter
- trip distance (taximeter)
- password protection for resetting of fuel consumption and trip counters and also for changing of OC working parameters
- different modes of run, turns, charge of fuel correction - its accuracy will not change, for example, after installation of trunks with slightly other diameter.
- signal on excess of the set speed, tachometer or on time (alarm clock)
- it works with any electronic blocks for engine control (ECU); it can be established on absolutely any gasoline cars with electronic injection system.
- it is simple to use - the device is controlled with only three buttons of regular clock in any operating mode
- the device is supplied by context helps about possible actions in the form of a scroll line
more info: http://eng.tandem-e.com
Blue Lanos
Příspěvek od Blue Lanos »
Thanks valeryss for info ;) I was reinitiate this action here :D I´m very honour with your activity. You would prepare some idea how to get the car computer to Czech and Slovakia. We prefer english translation.
Mentioned CC seems to be very good equipmnet ;)
valeryss
We need dialers in Slovakia.
We need dealers in Slovakia.
Zpět na „LANOS“
