Trip Computer - vers. 4.0 SPORT - Lanos - Sens
SERG Electronics
Příspěvek od SERG Electronics »
Ordering a patch of trip computers you can inquire an English insertion on all the patch /for any serially output model of trip computers/
Trip Computer vers. 4.xx SPORT
http://www.tripcomputer.ru/
Darrio
Příspěvek od Darrio »
Nevie niekto po rusky? Je to zaujimave z tych obrazkov, ale co vsetko to dokaze? A co by to stalo?
Daewoo Lanos 1,5 S, 14"CMS 185/60 R14 Barum Bravuris, CD/MP3 Panasonic, centrál, alarm, tlmiče Monroe Reflex
SkylineGTR
Příspěvek od SkylineGTR »
Waw, to vypadá good a umí to i průměrnou spotřebu?
vaculcim
Příspěvek od vaculcim »
Darrio píše:Nevie niekto po rusky? Je to zaujimave z tych obrazkov, ale co vsetko to dokaze? A co by to stalo?
Souhlas, co trochu více info?
2x Škoda Felicia, Seat Cordoba, Škoda 105L, Škoda Favorit a konečně Lanos 1,6 SX r.v.98, 195/50 R15, na zimu 185/60 R14
SERG Electronics
Hello!
You were looking for trip computer for your automobile. But the problem
was that our device had only Russian interface. Now we have developed
English version of it.
The main measurements and functions of Trip Computer v. 4.0 is:
- consumption of fuel, L per hour, L per 100 km
- precise tachometer, rpm
- precise speedometer, km/h
- average speed, km/h
- average fuel consumption per 100 km, L per 100 km
- fuel volume in tank, L
- forecast of the run on remaining fuel, km
- fuel consumed, L
- run, km
- on-board voltage, V
- temperature (inside and (or) outside), C
- clock and calendar
- the price of the fuel consumed, $ or Euro
- average price of 100 km run, $ or Euro per 100 km
Also, you can find several special functions in the device:
- set up (correction of all measurements)
- log book (history of your latest 80 trips)
- reset of the run and the fuel counters
- acceleration time to 100 km per hour
- device info
The installation of the trip computer is very simple. You need to connect
only 7 wires. Four of this 7 wires present on your clock.s connection. And
the other three wire is to be connected to injector, speed sensor and fuel
level sensor.
The device is to be installed instead of the clock of the automobile.
The trip computer can measure the temperature if the temperature sensors
are connected to it. You can use one or two sensors as well as don.t use
it at all.
best regards,
www.tripcomputer.ru
Naposledy upravil(a) SERG Electronics dne pon led 05, 2009 10:05, celkem upraveno 1 x.
vado
Příspěvek od vado »
Podla popisu to bude len dizajnovo "prezleceny" comp jeden z popisanych tu (viac to pasuje na Pilot-07, dokonca aj cenou)
https://www.chevroletclub.cz/viewtopic.php?t=4738
Problem je len malicky - dostat ich na SK a CZ. Nejake pokusy boli:
https://www.chevroletclub.cz/viewtopic.php?t=4436
Nedopadlo to dobre. Ja osobne sa do toho uz nemam chut pustat, financne mi to pripada dost rizikove, jedine ze by bol niekto vlastnikom nejakej firmy, doviezol na SK a CZ nejaky pocet kusov a tu ich normalne predaval, samozrejme aj so zarukou (dost drahe, aby som to v pripade poruchy po zopar tyzdnoch prevadzky iba tak zahodil do kosa) ...
Individualny nakup by okrem 80+16 (2x teplotne cidlo - Interier/Exterier teplota) USD vysiel hadam aj na dvojnasobok - postovne, prevod penazi, ...
V.
orgi
Příspěvek od orgi »
vado píše:Podla popisu to bude len dizajnovo "prezleceny" comp jeden z popisanych tu (viac to pasuje na Pilot-07, dokonca aj cenou)
vyzera to super, len tie nakaldy s tym spojene - postovne, prevod peniazkov, cele je to bez zaruky za vysledok.. a hlavne tie nervy :)
Zpět na „LANOS“
